vl-vplayer-set-transparency
(vl-vplayer-set-transparency layer
viewport transparency)
This function sets the viewport-specific
transparency override for the layer.
(layer
can specify one or more layers)
Arguments |
layer specifies one or more layer(s) to apply the
viewport-specific transparency |
Return |
T if the transparency value is successfully applied, NIL otherwise |
Example |
Remarks |
