Automatic LISP + VBA Loading
There are several ways to
automatically load Lisp, VBA and BRX/NET files, mostly compatible
with similar functionality found in other CAD systems.
The most-often used and well-known mechanisms
for Lisp modules :
for BRX/NET modules :
for VBA modules :
Since V17: Registry-based DemandLoad + Appload's "AutoLoad"
With BricsCAD V17, there are
2 more mechanisms to automatically load Lisp, VBA and BRX/NET
modules during startup and per-drawing (respectively), and on
command invocation.
The Appload
Dialog has been redesigned, and offers
an "AutoLoad" feature, to load designated Lisp, VBA, BRX/NET
modules during startup (and in case of Lisp programs, for each
drawing opened/created).
Informations are stored in "appload.dfs" file
(searched for in SupportPaths), and the associated "AutoLoad"
status for each file is stored in Registry, under current
profile.
This means, Appload Dialog mechanism is
per-profile and per-user.
For more details, please see topic
Appload
Dialog.
Additionally, the
Registry-based DemandLoad mechanism has been extended to support Lisp and VBA files
as well.
Now it is possible, to define
DemandLoad/Registry-based loading of Lisp and VBA application
files, on BricsCAD startup and for each drawing opened/created, as
well as Lisp/VBA application code loading, based on entering a
command by user (or from other application code).
Registry
DemandLoad.
Important hint for all AutoLoad mechanisms
There is a BricsCAD-specific
Lisp function (vl-list-loaded-lisp), which can help Lisp developers and applications, to work
independent on SupportPaths setting.
After an application's LISP file was loaded,
by any of the mentioned mechanisms, (vl-list-loaded-lisp) returns a
list of loaded Lisp files, and the Lisp files are specified with
their full path included - the application can check for an
"magic" file there, and extract the folder of that "magic" Lisp
file
=> hence, a Lisp application can
dynamically determine its "home / installation folder" at runtime,
and assign that path to a global variable.
example :
assume, the application's home folder is
assigned to a variable $HomeFolder_MyApp; later on, any loading of
Lisp, DCL, VBA files might use that home folder variable always
(setq MyAppFile1 (findfile (strcat
$HomeFolder_MyApp "MyLisp1.lsp")))
(if MyAppFile1 (load MyAppFile1)) (alert "*
Installation Error"))
This way, a Lisp application can work entirely
without any dependency on SupportPaths.
