BricsCAD-specific Lisp Error Control Functions and Variables
There are a number of
specific Lisp functions provided by BricsCAD Lisp engine, which are
likely not present in other AutoLISP compatible CAD systems' Lisp
engines.
Therefore, using these BricscCAD-specific Lisp
functions will cause your Lisp code to fail when running on other
CAD systems - so it is in developers responsibility to carefully
use them.
We plan to duplicate (most of) these functions
to the VLE Function Library, as this allows to make them available on other CAD
platforms as well (wherever possible), providing better
compatibility for developers' Lisp applications; this means, these
functions documented here will always remain implemented, but VLE
functions should be preferred.
© Bricsys NV. All rights reserved. |
