Sets or returns the linetype of an entity. The default linetype is the linetype of the layer (BYLAYER).
Applies to All Drawing objects, AttributeReference, Group or Layer
Syntax
Where:
stringVariable is a variable for storing the linetype name.
object is the applicable entity object;
string is the name of a linetype to be assigned to an entity.
Examples...
© Bricsys NV. All rights reserved. |
