Sets or returns the linetype scale of an entity. Applies to All Drawing objects, AttributeReference or Group. The linetype scale of an object specifies the relative length of dash-dot linetypes per drawing unit.
The value is a positive real number. The default is 1.0
Syntax
Where:
doubleVariable is a double-precision variable or number for storing the linetype scale.
object is the applicable entity object;
double is the value of the linetype scale.
Examples...
LineTypeScale property example
© Bricsys NV. All rights reserved. |
