bim:set-description
(bim:set-description  entity  description)
Assigns the BIM object description string for the specified entity.
Arguments
entity  any entity (as normal entity or as VLA object name) to assign the BIM object name to
description  information (string) to be attached to the entity (can be empty)
Return
T is successfully assigned, NIL otherwise
Example
(bim:set-description ent "room 1")  returns T
Remarks
same as (bim:set-property entity "Description" "room 1")
©  Bricsys NV. All rights reserved.
