command-s
(command-s [ item1 [ item2 ... ]]
This function calls the native command
sequence; (command-s) cancels the running command or option
input.
Arguments |
item1 any native BricsCAD command or option |
Return |
always NIL |
Example |
(command-s "_layer" "_color" 2 "MyLayer" "") |
Remarks |
same as (command) function, no difference for both versions in BricsCAD |
