dlg-sysvars
(dlg-sysvars)
This function opens the "System Variables"
dialog, listing all available System Variables with their actual
values in a resizable window.
Arguments |
none |
Return |
always returns 'void' (no return value, like (princ) function), to allow transparent usage of (dlg::sysvars) |
Example |
(dlg-sysvars) |
Hints |
a) doubleclick on a system
variable (or select and use "Help" button) to open the
Settings dialog to
review or change the value. |
© Bricsys NV. All rights reserved. |
