dos_copy
(dos_copy sourceFileSpec
destFileSpec)
This function copies one or more source files
to a target file resp. to a target folder;
the source file specification may contain
wildcard characters like "*" and "?".
sourceFileSpec : (string) specifies an existing file (no wildcards used),
or declares a file mask when using wildcards
destFileSpec : (string) specifies the target file, if sourceFileSpec also specifies
an existing file -OR-
it specifies a folder to copy all source files
to, if sourceFileSpec
Examples :
(dos_copy "J:\\1.txt" "J:\\2.txt")
"J:\\Test\\2.txt")
"J:\\TestXXX\\")
(dos_copy "J:\\*.txt" "J:\\Test\\")
Note 1 : any
existing target file will be overwritten !
Note 2 : missing
target folder(s) will be automatically created
Note 3 : when
specifying a target folder, the string must end with "\\" or "/"
character to clearly declare it to be a folder !
Note 4 : both "\\"
and "/" path separators are allowed on all platforms (Windows,
Linux, Mac; they will be adjusted automatically)
