layerstate-addlayers
(layerstate-addlayers  layerState  layerDef  [ layerDef ... ] ))
This function adds 1 or more layers, with their intended settings, to the layer state layerState.
Arguments
layerState  (string) name of the LayerState to add the specified layers to
layerDef  (list) layer definition to be added to the LayerState
layerDef  is a list of (layerName status color linetype lineweight plotstyle) :
layerName : (string) name of the layer to add
status : (integer) combined from bit flags - 1=Off  2=Frozen  4=Locked  8=NoPlot  16=FrozenInNewVPort
color : (dotted pair) color definition, either (62 . <IndexColor>) or (420 . <TrueColor>)
lineweight : (integer) one of the valid LineWeight values
plotstyle : (string) name of the plotstyle
any value can be specified as NIL - then the default value is used (current drawing value)
Return
T if successfully added, NIL otherwise
Example
(layerstate-addlayers  "myLayerState"
  (list "Window" 4 '(62 . 2) "Dashed" 10 "Color_2")
  (list "Roof" 5 '(420 . 1420266) "Continuous" 20 nil)
adds 2 layers to the LayerState
Remarks
©  Bricsys NV. All rights reserved.
