layerstate-importfromdb
(layerstate-importfromdb  layerState  filename)
This function imports the specified LayerState from given dwg file.
Arguments
layerState  (string) name of the LayerState to be imported
filename  (string) name of the dwg file to import the specified LayerState from
Return
returns T if the LayerState was properly imported from the dwg file, NIL otherwise
Example
(layerstate-importfromdb “WallLayers“ “d:/WallLayers.dwg“)  T
Remarks
©  Bricsys NV. All rights reserved.
