mech:compdef-get-filepath
(mech:compdef-get-filepath
blkRefOrSolid)
Returns the path to the dwg file containing
the definition of the (external) component referenced by
blkRefOrSolid (ename) entity, where it is defined as a root
component.
Arguments |
blkRefOrSolid (ename) the entity to query |
Return |
file path (string) on success, or NIL in case of an error |
Example |
(vl-load-mech)
1 |
Remarks |
blkRefOrSolid could be a BlockReference or 3dSolid |
Note |
returned file path string can be empty |
