mech:compdef-set-custompropertyvalue
(mech:compdef-set-custompropertyvalue
blkRefOrSolid category property
value)
Assigns a new value for the property
name contained in
PropertySet category
for the blkRefOrSolid (ename)
entity.
Arguments
blkRefOrSolid
(ename) the entity
category (string)
the Category/PropertySet containing the name property
property (string)
the name of the property to be changed
value (integer/double/string/T/NIL) value to be
assigned
Return
T on success, or NIL in case
of an error
Example
(vl-load-mech)
1
(setq blkRefOrSolid (entlast))
<Entity name: 7e4ddcf0>
(setq res
(mech:compdef-get-custompropertyvalue blkRefOrSolid "Test"
"TestProp"))
("Test" "TestProp" "zzz" "zzz")
(setq res
(mech:compdef-set-custompropertyvalue blkRefOrSolid "Test"
"TestProp" "0000"))
T
(setq res
"TestProp"))
("Test" "TestProp" "0000" "0000")
Remarks
blkRefOrSolid
could be a BlockReference or
3dSolid
Note
1. the
Category/PropertySet category
must already exist
2. if the property does not exist yet,
it is automatically created inside the category PropertySet
to create and assign a new
CategoryPropertySet, see function (mech:compdef-assign-propertyset)
