mech:compdef-set-sectionable
(mech:compdef-set-sectionable  blkRefOrSolid  isSectionable)
 Defines whether the component, referenced by the blkRefOrSolid (ename) entity, is sectionable or not.
Arguments
blkRefOrSolid (ename) the entity
isSectionable T/NIL defines whether the referenced ComponentDefinition is sectionable or not
Return
T on success, or NIL in case of an error
Example
(vl-load-mech)  1
(setq blkRefOrSolid (entlast))
<Entity name: 7dabeda0>
(setq res (mech:compdef-get-issectionable blkRefOrSolid))
nil
(setq res (mech:compdef-set-sectionable blkRefOrSolid T))
T
T
Remarks
blkRefOrSolid could be a BlockReference or 3dSolid;
changing the "sectionable" status might affect other instances using the same ComponentDefinition
Note
©  Bricsys NV. All rights reserved.
