mech:parameters-erase
(mech:parameters-erase  blkId  parameter)
Removes the specified parameter (integer).
Arguments
parameter (integer) the parameter identifier to be erased
Return
T if successful, or NIL otherwise
Example
(vl-load-mech)  2
(setq blkId (tblobjname "BLOCK" "*Model_Space"))  <Entity name: 4aaa68b0>
(setq param (mech:parameters-get-byname blkId "Length"))  971708080
(mech:parameters-erase param)  T
Remarks
Note
©  Bricsys NV. All rights reserved.
