mech:parameters-get-name
(mech:parameters-get-name  parameter)
Returns the name (string) of the specified parameter (integer).
Arguments
parameter (integer) the parameter identifier to query
Return
name of the parameter (string), or NIL
Example
(vl-load-mech)  2
(setq blkId (tblobjname "BLOCK" "*Model_Space"))  <Entity name: 4aaa68b0>
(setq param (mech:parameters-get-byname blkId "Length"))  971708080
(mech:parameters-get-name param)  "X"
Remarks
Note
©  Bricsys NV. All rights reserved.
