slide_image
(slide_image xpos ypos width height slidename)
This function shows the specified slide image slidename inside the currently active DCL tile.
Arguments
xpos  (number, >= 0) offset in X direction, from upper-left corner of the DCL tile
ypos  (number, >= 0) offset in Y direction, from upper-left corner of the DCL tile
width  (number, >= 0) width of the image (pixels)
height  (number, >= 0) height of the image (pixels)
slidename  (string) name of the slide image to be shown, either <name.sld> or <library.slb(name)>
Return
(string) returns slidename if successful, NIL otherwise
Example
(slide_image 2 2 16 16 "icon.sld")"
(slide_image 2 2 16 16 "sldLibrary.slb(icon)")
Remarks
the currently active DCL tile is the one set active by (start_image) function
©  Bricsys NV. All rights reserved.
