tinc:createboundarybypoints
(tinc:createBoundaryByPoints  ename
 type  points)
Creates a boundary constraint of
type using
points for
the ename TinSurface entity; returns integer identifier or
NIL.
 Arguments  |
 ename  (ename) the TinSurface entity  |
 Return  |
 (integer) ID, identifier of the constraint, or NIL if the operation fails  |
 Example  |
 (setq points '((20 20)(60
20)(60 60)(20 60)))  |
 Remarks  |
 for the boundary constraint type, see Type Constants  |
