tinc:createbreaklinebypoints
(tinc:createBreaklineByPoints ename
type points elevType)
Creates a breakline constraint of
type using
points and
elevType for the
'ename' (ename) TinSurface; returns ID identifier (integer) or
NIL.
Arguments
ename (ename) the TinSurface entity
type (integer 0...1) type of the breakline constraint to
be created (bcTinBreaklineNomal 0, bcTinNonDestructive
1)
points (list
of 2d/3d points) list of points, defining the breakline
contour
elevType (integer 1...3, bcTinElevationMin 1,
bcTinElevationMax 2, bcTinElevationMid 3) defines the elevation
type for the breakline constraint
Return
(integer) ID, identifier of
the constraint, or NIL if the operation fails
Example
(setq points '((30 30)(50
30)(50 50)(30 50)))
(setq constraint (tinc:createBreaklineByPoints
tin bcTinBreaklineNomal points bcTinElevationMid))
tin bcTinNonDestructive points bcTinElevationMid))
tin bcTinBreaklineNomal points bcTinElevationMin))
tin bcTinNonDestructive points bcTinElevationMin))
Remarks
type, see Type
Constants
