tinc:getmidordinatedistance
tinc:getMidOrdinateDistance ename
constraint)
This function returns the mid-ordinate-distance of
the constraint for the ename
TinSurface entity or NIL.
Arguments |
ename (ename) the TinSurface entity to
query |
Return |
(double) the mid-ordinate-distance value, or NIL |
Example |
(tinc:getmidordinatedistance tin constraint) 0.05 |
Remarks |
the mid-ordinate distance is the
distance of the curve's midpoint, to the arc center; similar to
arc's bulge; used as a kind of tolerance; |
