tin:setsurfaceelevation
(tin:setsurfaceelevation  tinEname  elevation)
This function sets all definition points of the tinEname TinSurface entity to a Z value of elevation.
Arguments
tinEname  (ename or vla-object)  the TinSurface entity to assign the name
elevation  (number)  sets a fixed Z elevation for the entire TinSurface (all points get the same Z value)
Return
T or NIL
Example
(tin:setsurfaceelevation tin -20.0)  T
all points used by the TinSurface are set to a Z value of -20.0
Remarks
©  Bricsys NV. All rights reserved.
