vl-doc-import
(vl-doc-import appName [ 'functionA [
'functionB ... ] ] )
This function imports the specified list of
functions functionA functionB ... from
appName module
using an own "separate NameSpace", into the calling "separate
NameSpace" module.
Arguments |
appName (string) name of an application, from a DES compiled
Lisp file; it is the DES Lisp file name (without path +
extension) |
Return |
always returns T (or triggers an error, if appName is not a loaded Lisp application, or is not a "separate NameSpace" module) |
Example |
if "MyApp.des", generated
with "Separate NameSpace" feature, is loaded : |
Remarks |
this function can be used
inside a "separate NameSpace", to import functions from other
"separate NameSpace" module; |
