vl-file-directory-p
(vl-file-directory-p pathName)
This function verifies whether pathName
specifies an existing folder name.
Arguments |
pathName (string) name of a directory / folder |
Return |
T if pathName is an existing folder, NIL otherwise |
Example |
Remarks |
if pathName does not contain a path, the actual OS folder is used to search for the specified folder |
