vl-file-rename
(vl-file-rename oldName newName)
This function renames the file oldName to a new name newName.
Arguments
oldName  (string) specifies the existing file; if no path is included, the file is searched in the current OS folder
newName  (string) new name for the file
Return
T if renaming succeeded, NIL in case of an error
Example
Remarks
if a file with name newName does already exist, the function will fail
©  Bricsys NV. All rights reserved.
