vl-layerstates-setpropertymask
(vl-layerstates-setpropertymask  lstate  bitFlags)
sets the default behaviour flags for specified LayerState 'lstate'
Arguments
lstate  a string or symbol specifying the LayerState
bitFlags  an integer combining the bits which control default behaviour;
-1 specifies "All" (same as 1023); also 65535 (=0xFFFF) can be used
0 None
1 On
2 Frozen
4 Locked
8 Plot
16 NewViewport
32 Color
64 LineType
128 LineWeight
256 PlotStyle
512CurrentViewport
Return
T if successful, NIL otherwise
Example
(vl-layerstates-setpropertymask "MyLayers_1" 6) : sets the LayerState as Frozen + Locked
Remarks
this is a BricsCAD-specific function !
©  Bricsys NV. All rights reserved.
