vl-prin1-to-string
(vl-prin1-to-string lspObject)
This function returns lspObject converted into a string, using (prin1) logic.
Arguments
lspObject  (any Lisp value or expression) the Lisp data to be converted
Return
(string) the representation of lspObject as a string
Example
(setq lst '(1 2.0 "a"))  (1 2.0 "a")
(vl-prin1-to-string lst)  "(1 2.0 \"a\")"
Remarks
this function uses same conversion rules as (prin1) function
see (vl-princ-to-string) function
©  Bricsys NV. All rights reserved.
