vl-string-elt
(vl-string-elt string index)
This function returns the integer value for
the character at the index
position in string.
Arguments
string (string) the string to return the indexed character
value
index (integer) the index for the character; 0 is
the index of the first character
Return
(integer) the integer value
for the specified character
Example
(vl-string-elt " abc" 0)
32
(vl-string-elt "abc" 2) 99
Remarks
if index is outside the
string length, an error is triggered;
in BricsCAD, each character in a string is
represented by its Unicode value; therefore, forward and backward
conversion between visual representation (the character) and its
numerical representation (the Unicode value) is always constant
across all platforms and versions, local code pages have no
impact;
additionally, there is always a 1-to-1
relation (length of a string is identical to number of characters,
and number of Unicode values);
this is different from AutoCAD AutoLISP, where
all these conditions are not ensured, and therefore the backward +
forward conversion is rather useless, and also depends on local
code pages;
see (vl-list->string) function
