vl-string-search
(vl-string-search pattern string [ fromPos ]
This function returns the position of
pattern sub-string
in string.
Arguments |
pattern (string) the string to be searched |
Return |
(integer) position of the pattern string as found in string; NIL if not found |
Example |
(vl-string-search "test" "?
test is a test ?") 2 |
Remarks |
first character position/index in string is at index 0 |
