vl-string-trim
(vl-string-trim charset string)
This function removes all leading and trailing
characters contained in charset
from the start and end of the
string.
Arguments |
charset (string) a string containing all characters to be
removed |
Return |
(string) result string after removing all leading + trailing characters contained in charSet from the input string |
Example |
(vl-string-trim " #/" " #;; now a valid comment #/ ") returns ";; now a valid comment" |
Remarks |
© Bricsys NV. All rights reserved. |
