vl-vlx-loaded-p
(vl-vlx-loaded-p appName)
This function verifies whether a NameSpace-enabled application appName is currently loaded.
Arguments
appName  (string) the name of a VLX compiled application
Return
T if appName loaded, NIL otherwise
Example
Remarks
the "application name" is the file name without path and extension
©  Bricsys NV. All rights reserved.
