vl-vplayer-get-linetype
(vl-vplayer-get-linetype  layer  viewport)
This function returns the viewport-specific linetype override value for the layer.
Arguments
layer  specifies the layer to retrieve the viewport-specific linetype override
can be :
1. name  (string)  the name of the layer
2. ename  (ename)  the entity name of the layer
viewport  specifies the viewport
can be
1. ename  (ename) the viewport's entity name
2. cvport  (integer)  the viewport's CVPORT viewport number
Return
list (linetype isOverride)
linetype  (string)  the linetype name
isOverride  T indicates that the value is a true override, NIL indicates a normal property value
Example
Remarks
this is a BricsCAD-specific function !
©  Bricsys NV. All rights reserved.
