vl-vplayer-set-truecolor
(vl-vplayer-set-truecolor  layer  viewport  rgbColor)
This function sets the viewport-specific rgbColor truecolor override for the layer;
(layer can specify one or more layers)
Arguments
layer  specifies one or more layer(s) to apply the viewport-specific truecolor
can be :
1. name  (string)  the name of 1 layer
2. ename  (ename)  the entity name of the layer
3. enameList  (list of name | ename)  list of 1 or more layer entity string names and/or enames
viewport  specifies one or more viewport
can be
1. ename  (ename) the viewport's entity name
2. cvport  (integer)  the viewport's CVPORT viewport number
3. (list ename cvport ...)  list ename(s) and/or cvport(s)
rgbColor  (integer)  the truecolor value to be assigned; if NIL, any truecolor override is removed
Return
T if the truecolor value is successfully applied resp. removed, NIL otherwise
Example
Remarks
this is a BricsCAD-specific function !
©  Bricsys NV. All rights reserved.
