vlax-curve-getstartparam
(vlax-curve-getstartparam curveEnt)
This function returns the "start parameter" of the curveEnt curve entity.
Arguments
curveEnt  (ename or vla-object) the COM object of any "curve" entity
Return
double;  the start parameter of the curve or NIL
Example
last entity is a LINE<0,0,0> to <10,10,10> :
(setq ent (vlax-ename->vla-object (entlast)))  #<VLA-OBJECT IAcadLine 000000004E8E3928>
(vlax-curve-getstartparam ent)  0.0
Remarks
for most entities, the "start parameter" is 0.0 - but there is no guarantee for this !
never assume the "start parameter" to be 0.0, always query the entity for its "start parameter" !
©  Bricsys NV. All rights reserved.
