vlax-for
(vlax-for item vlaCollection [ exprA [ exprB ... ] ] )
This function evaluates each item from vlaCollection by exprA exprB ... and returns the last evaluated expression value.
Arguments
item  (string) name of a Lisp variable (not symbol)
vlaCollection  (VLA-Object) any COM collection object
exprA  (any Lisp expression) expression to be evaluated
exprB  (any Lisp expression) expression to be evaluated
Return
the value of the last evaluated expression (for last collection item)
Example
(vlax-for item (vla-get-layers ...) (setq name (vla-get-name item) ...)
queries for the 'Name' property of all layers
Remarks
Note : the loop variable ('item' in above sample) is a local variable to the (vlax-for ...) scope !
if 'item' is declared as global or local variable in actual (defun ...) scope, then 'item' will have its former value, after the (vlax-for ...) statement !
©  Bricsys NV. All rights reserved.
