vlax-get-object
(vlax-get-object COM-Id)
This function returns an existing instance of the COM server object identified by COM-Id.
Arguments
COM-Id  (string) identifies the COM server object by its name
Return
VLA-OBJECT;  the COM server object, or NIL if no running COM server exists
Example
(setq cad (vlax-get-object "BricscadApp.AcadApplication"))
#<VLA-OBJECT IAcadApplication 000000002E5710D0>
Remarks
see (vlax-create-object) function;
see (vlax-get-or-create-object) function
©  Bricsys NV. All rights reserved.
