vlax-release-object
(vlax-release-object vlaObject)
This function releases the vlaObject COM object
(decrements its "reference counter").
Arguments |
vlaObject (VLA-Object) any COM object |
Return |
integer, indicates the actual
"reference counter" of the COM object; |
Example |
(setq ent
(vlax-ename->vla-object (entlast))) #<VLA-OBJECT
IAcadLine 0000000039E12370> |
Remarks |
releasing an already released object is safe, and does not trigger an error in BricsCAD (but does trigger an error on other CAD systems) |
© Bricsys NV. All rights reserved. |
