vlax-safearray-put-element
(vlax-safearray-put-element saVar index1 [ index2 [ index3 ... ] ] ] value)
This function assigns value to the saVar SafeArray at index specified by index1, index2, index3 ...
Arguments
saVar  (SafeArray) the SafeArray to assign the indexed value to
index1  (integer)  the index for the first dimension
index2  (integer, optional)  the index for the second dimension
index3  (integer, optional)  the index for the third dimension
value  (any suitable Lisp or COM data item)  the value to be assigned
Return
the value argument
Example
(setq sa (vlax-make-safearray vlax-vbDouble '(0 . 1) '(0 . 2)))  #<safearray...>
(vlax-safearray-fill sa '((1.0 2.0 3.0) (10.0 11.0 12.0)))  #<safearray...>
(vlax-safearray-get-element sa 1 2)  12.0
(vlax-safearray-put-element sa 1 2 99)  99
(vlax-safearray-get-element sa 1 2)  99.0
Remarks
see (vlax-make-safearray) function
©  Bricsys NV. All rights reserved.
