vlax-write-enabled-p
(vlax-write-enabled-p vlaObject)
This function verifies whether vlaObject is actually write-enabled.
Arguments
vlaObject  (VLA-Object) any COM object
Return
T if the object is write-enabled, NIL otherwise (i.e. object is erased, or only open for read access)
Example
Remarks
if the object is "write-enabled", it can be modified (otherwise any modification will trigger an error)
©  Bricsys NV. All rights reserved.
