vle-vector-angletoref
(vle-vector-angletoref  vec1  vec2  normal)
This function returns the angle between vectors vec1 and vec2, using normal as reference vector, which defines the vector plane.
Arguments
vec1  a 2d or 3d vector list
vec2  a 2d or 3d vector list
normal  a 2d or 3d vector list, specifies the plane normal
Return
double, angle in radians, in range 0 ... 2PI
Example
(setq v1 '(2 0 0) v2 '(0 3 0) normal '(0 0 1))
(vle-vector-angletoref v1 v2 normal)
1.5707963267949
(setq v1 '(2 0 0) v2 '(-1 -1 0) normal '(0 0 1))
3.92699081698724
Remarks
input vectors must not be unit-length (non-normalised vectors are allowed)
©  Bricsys NV. All rights reserved.
