vlr-acdb-reactor
(vlr-acdb-reactor customData
callbackList)
This function creates and attaches a Database
operation reactor to the current drawing, for the database events
specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-objectAppended
an object has been added to
the dwg database
:vlr-objectUnAppended
an object has been removed
from the dwg database (i.e. by undo operation)
:vlr-objectReAppended
an object has been re-added
to the dwg database (i.e. by redo operation)
:vlr-objectOpenedForModify
an object has been opened for
write (i.e. to be modified afterwards)
:vlr-objectModified
an object has been
modified
:vlr-objectErased
an object has been erased
(i.e. by (entdel)
function)
:vlr-objectUnErased
an object has been unerased
(i.e. by (entdel)
function)
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
database reactor object - #<VLR-AcDb-Reactor>
args : (list)
first list entry is the database which is affected, the second
entry is the object being appended to that database -
(#<VLA-OBJECT IAcadDatabase 000000003AA5B598> <Entity
Return
the reactor object
#<VLR-AcDb-Reactor> or NIL
Example
Remarks
