vlr-lisp-reactor
(vlr-lisp-reactor customData callbackList)
This function creates and attaches a Lisp operation reactor to the current drawing, for the command events specified by callbackList.
Arguments
customData  (any valid Lisp data) custom data to be associated with the reactor object, can be NIL
callbackList  (list)  list of DottedPair entries, each DottedPair has the form
(event . callback)
event : one of these symbolic constants
:vlr-lispWillStart
a Lisp expression is about to be evaluated
:vlr-lispEnded
Lisp expression is has been finished (on outermost Lisp expression)
:vlr-lispCancelled
Lisp expression has been cancelled
callback : the client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args / ...) ...)
reactor : the lisp reactor object - #<VLR-Lisp-Reactor>
args : (list) contains 0...1 arguments, depending on the particular event :
:vlr-lispEnded
:vlr-lispCancelled
0 arguments
:vlr-lispWillStart
1 argument (string)
the first line of the Lisp expression to be evaluated
Return
the reactor object #<VLR-Lisp-Reactor> or NIL
Example
Remarks
©  Bricsys NV. All rights reserved.
