vlr-object-reactor
(vlr-object-reactor objects customData
callbackList)
This function creates and attaches a database
Object operation reactor to the current drawing, for the command
events specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constant
:vlr-cancelled
modification of the object
was cancelled
:vlr-copied
an object has been
copied
:vlr-erased
an object has been
erased
:vlr-unerased
an object has been
unerased
:vlr-goodbye
an object has been (finally)
deleted
:vlr-openedForModify
an object has been opened for
modification
:vlr-modified
an object has been
modified
:vlr-subObjModified
a sub-object has been
erased
:vlr-modifyUndone
an object's modification has
been undone
:vlr-modifiedXData
an object's XData has been
modified
:vlr-unappended
an object has been removed
from its database
:vlr-reappended
an object has been
re-appended to the database
:vlr-objectClosed
an object's modifications
habe been finished (committed)
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
object reactor object - #<VLR-Object-Reactor>
args : (list)
contains 0...1 arguments, depending on the particular event
:vlr-cancelled
:vlr-erased
:vlr-unerased
:vlr-goodbye
:vlr-modified
:vlr-modifyUndone
:vlr-modifiedXData
:vlr-unappended
:vlr-reappended
:vlr-objectClosed
0 arguments
:vlr-copied
1 argument
(ename)
the object created by copy
operation
:vlr-subObjModified
1 argument
(ename)
the sub-object which has been
modified
Return
the reactor object
#<VLR-Object-Reactor> or NIL
Example
Remarks
