vlr-owner-remove
(vlr-owner-remove objReactor
object)
This function removes the object from the
specified objReactor
ObjectReactor.
Arguments |
objReactor
(object object VLR-Object-Reactor)
the reactor to remove the specified object from |
Return |
object is returned always (regardless whether object is monitored or not) |
Example |
(setq rx (vlr-object-reactor
nil nil '((:vlr-modified . cb))))
#<VLR-Object-Reactor> |
Remarks |
see also (vlr-owner-add) and (vlr-owners) functions |
© Bricsys NV. All rights reserved. |
