vlr-reactors
(vlr-reactors [ reactorTypeA [ reactorTypeB ... ] ] )
This function returns a list of all active reactors.
Arguments
reactorTypeA  (symbol, optional)  reactorType symbol
reactorTypeB  (symbol, optional)  reactorType symbol
if no reactorType is specified, all active reactors are returned;
reactorType is one (or more) of the following symbols :
:VLR-AcDb-Reactor
database reactor
:VLR-Command-Reactor
command reactor
:VLR-DeepClone-Reactor
deepclone reactor (cloning in same database)
:VLR-DocManager-Reactor
document manager reactor
:VLR-DWG-Reactor
drawing reactor
:VLR-DXF-Reactor
DXF operation reactor
:VLR-Editor-Reactor
CAD editor reactor
:VLR-Insert-Reactor
insert operation reactor
:VLR-Linker-Reactor
BRX module loader reactor
:VLR-Lisp-Reactor
Lisp events reactor
:VLR-Miscellaneous-Reactor
reactor covering several other events + operations
:VLR-Mouse-Reactor
mouse event reactor
:VLR-Object-Reactor
object + entity operation reactor
:VLR-SysVar-Reactor
system variables reactor
:VLR-Toolbar-Reactor
toolbar operation reactor
:VLR-Undo-Reactor
undo operation reactor
:VLR-Wblock-Reactor
wblockclone reactor (cloning between different databases)
:VLR-Window-Reactor
window operation reactor
:VLR-XREF-Reactor
xref operation reactor
Return
list of activeReactor entries, or NIL;
each activeReactor element is a list of form (reactorType reactor reactor ...)
Example
(setq rx1 (vlr-object-reactor nil nil '((:vlr-modified . cb1))))  #<VLR-Object-Reactor>
(setq rx2 (vlr-acdb-reactor nil '((:vlr-objectErased . cb2))))  #<VLR-AcDb-Reactor>
(vlr-reactors)
((:VLR-ACDB-REACTOR #<VLR-AcDb-Reactor>) (:VLR-OBJECT-REACTOR #<VLR-Object-Reactor>))
Remarks
©  Bricsys NV. All rights reserved.
