vlr-sysvar-reactor
(vlr-sysvar-reactor customData
callbackList)
This function creates and attaches a
SystemVariables operation reactor to the current drawing, for the
command events specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-sysVarWillChange
a system variable is about to
be changed
:vlr-sysVarChanged
a system variable has been
changed
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
SystemVariables reactor object -
#<VLR-Sysvar-Reactor>
args : (list)
contains 1...2 arguments, depending on the particular event
1 argument
(string)
name of the system variable
:vlr-sysVarChanged
2 arguments
1st argument : string, the name of the system
variable
2nd argument : integer 1=success,
0=failed
Return
the reactor object
#<VLR-Sysvar-Reactor> or NIL
Example
Remarks
