BricsCAD Lisp Memory Configuration
The BricsCAD LISP engine uses
an optimised internal memory management, for LISP heap and page
data, and a maximum memory block, based on the amount of RAM memory
installed in the particular machine.
In some very rare cases, especially the size
of the pre-allocated LISP memory block might not be sufficient, and
"out-of-memory" situation might appear (results in Lisp failures
then).
As a backdoor to bypass such out-of-memory
conditions, the BricsCAD LISP engine allows to adjust few memory
configuration settings, using the file "lispex.dll.cfg" which is
found in BricsCAD installation folder - it is a simple text file
with actually 3 settings, and can be edited with any plain ASCII
editor (notepad etc.).
These are the settings which can be adjusted :
