Sub Add3dFaceExample() ' This example creates and adds a 3D face to the drawing. ' Define the four coordinates of the face Dim Pt1(0 To 2) As Double: Pt1(0) = 0: Pt1(1) = 0: Pt1(2) = 0 Dim Pt2(0 To 2) As Double: Pt2(0) = 3: Pt2(1) = 0: Pt2(2) = 2 Dim Pt3(0 To 2) As Double: Pt3(0) = 6: Pt3(1) = 5: Pt3(2) = 0 Dim Pt4(0 To 2) As Double: Pt4(0) = 4: Pt4(1) = 4: Pt4(2) = 2 ' Add the 3DFace object Dim faceObj As Acad3DFace Set faceObj = ThisDrawing.ModelSpace.Add3DFace(Pt1, Pt2, Pt3, Pt4) faceObj.Update ThisDrawing.Application.ZoomExtents End Sub
© Bricsys NV. All rights reserved. |
