Sub AddArcExample() 'This example adds an arc to the drawing. Dim myArc As AcadArc Dim ctrPt(0 To 2) As Double ctrPt(0) = 5: ctrPt(1) = 3 'Add the arc to the .dwg Set myArc = ThisDrawing.ModelSpace.AddArc(ctrPt, 2.5, toRadians(15), toRadians(105)) ' Display the entity myArc.Update ThisDrawing.Application.ZoomExtents MsgBox "Arc created w/ center point at 5,3.", vbInformation, "AddArc Example" End Sub Function toRadians(ByVal inDegrees As Double) As Double toRadians = inDegrees * 3.141592 / 180 End Function
© Bricsys NV. All rights reserved. |
