Adds a cylinder given the center, base radius, and height. The cylinder is drawn as a 3dSolid.
Syntax
Where:
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
Center is a Variant identifying the center of the cylinder;
Radius is a double-precision variable representing the radius of the cylinder;
Height is a double-precision variable representing the height of the cylinder.
Examples...
© Bricsys NV. All rights reserved. |
