AddRaster method example
Sub AddRaster_Example()
Dim insPoint(0 To 2) As Double
Dim scalefactor As Double
Dim rotationAngle As Double
Dim imageName As String
Dim rasterObj As AcadRasterImage
imageName = "C:test.jpg"
insPoint(0) = 4: insPoint(1) = 2: insPoint(2) = 0
scalefactor = 1
rotationAngle = 0
Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insPoint, scalefactor, rotationAngle)
rasterObj.Update
ThisDrawing.Application.ZoomExtents
MsgBox "The property .ImageFile is: " & rasterObj.ImageFile
MsgBox "The property .ImageHeight (in drawing units) is: " & rasterObj.ImageHeight & _
Chr(13) & "The property .ImageWidth (in drawing units) is: " & rasterObj.ImageWidth
MsgBox "The property .Height (in pixels) is: " & rasterObj.height
MsgBox "The property .Width (in pixels) is: " & rasterObj.width
MsgBox "The property .ImageVisibility is: " & rasterObj.ImageVisibility
End Sub
© Bricsys NV. All rights reserved. |
